Salta al contenuto principale
CyberPowerPC RGB 7 Color LED Backlight Replacement
Cosa ti serve
  1. CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: passo 1, immagine 1 di 2 CyberPowerPC RGB 7 Color LED Backlight Replacement, Plastic Casing: passo 1, immagine 2 di 2
    • Be sure to unplug the keyboard before starting the disassembly.
    • Remove the two 10 mm length screws using the Phillips head #1 which are located underneath the kickstand of the keyboard and directly next to it.
  2. CyberPowerPC RGB 7 Color LED Backlight Replacement: passo 2, immagine 1 di 2 CyberPowerPC RGB 7 Color LED Backlight Replacement: passo 2, immagine 2 di 2
    • Remove the sixteen 5 mm length screws using the Phillips head #2.
    • One of the screws may be located underneath a manufacturer's sticker.
  3. CyberPowerPC RGB 7 Color LED Backlight Replacement: passo 3, immagine 1 di 1
    • Lift up and remove the plastic casing.
  4. CyberPowerPC RGB 7 Color LED Backlight Replacement, LED Backlight: passo 4, immagine 1 di 1
    • Remove the metal backing located directly underneath the white plastic casing.
  5. CyberPowerPC RGB 7 Color LED Backlight Replacement: passo 5, immagine 1 di 1
    • Be careful not to pull too hard on the ribbon cable, as it may break.
    • Disconnect the ribbon cable that connects the LED board to the motherboard.
  6. CyberPowerPC RGB 7 Color LED Backlight Replacement: passo 6, immagine 1 di 1
    • Carefully remove the LED board, which should now come free from the casing.
Conclusione
Altre 2 persone hanno completato questa guida.
Braydon Lantz
Membro da: 02/12/18
229 Reputazione
2 Guide realizzate
USF Tampa, Team S15-G2, Boczar Spring 2018 Membro di USF Tampa, Team S15-G2, Boczar Spring 2018
USFT-BOCZAR-S18S15G2
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 35
Tutti i Tempi: 895
