Salta al contenuto principale
CyberPower UPS Battery Replacement
Cosa ti serve
    1. CyberPower UPS Battery Replacement, Battery: passo 1, immagine 1 di 2 CyberPower UPS Battery Replacement, Battery: passo 1, immagine 2 di 2
      • Power down the unit by pressing the power button until the display goes black.
      • This is usually about 3 seconds.
      • Unplug the power cord from the wall outlet.
      Chiedi a FixBot
      Aggiungi Commento
    2. CyberPower UPS Battery Replacement: passo 2, immagine 1 di 3 CyberPower UPS Battery Replacement: passo 2, immagine 2 di 3 CyberPower UPS Battery Replacement: passo 2, immagine 3 di 3
      • Remove the battery plate cover at the bottom of the UPS using a Phillips #1 screwdriver.
      • If the screwdriver is not magnetized, tap on the cover plate to completely remove the screw.
      Chiedi a FixBot
      Aggiungi Commento
    3. CyberPower UPS Battery Replacement: passo 3, immagine 1 di 2 CyberPower UPS Battery Replacement: passo 3, immagine 2 di 2
      • Slide the battery cover plate to the left.
      • Grasp the battery plate cover and lift it off the the UPS.
      Chiedi a FixBot
      Aggiungi Commento
    4. CyberPower UPS Battery Replacement: passo 4, immagine 1 di 3 CyberPower UPS Battery Replacement: passo 4, immagine 2 di 3 CyberPower UPS Battery Replacement: passo 4, immagine 3 di 3
      • Pull out the battery to expose the terminal connectors.
      • Use needlenose pliers to disconnect both battery terminal connectors.
      • Do not pull the connectors by the wires, pull connectors by grabbing the connector itself.
      • With the battery terminal connectors disconnected, slide the battery all the way out.
      Chiedi a FixBot
      Aggiungi Commento
    5. CyberPower UPS Battery Replacement: passo 5, immagine 1 di 3 CyberPower UPS Battery Replacement: passo 5, immagine 2 di 3 CyberPower UPS Battery Replacement: passo 5, immagine 3 di 3
      • The replacement battery should be a 12 volt, 9 amp-hour, sealed lead acid battery with f2 type connectors.
      • Install the new battery and reconnect the terminals.
      Chiedi a FixBot
      Aggiungi Commento
    6. CyberPower UPS Battery Replacement: passo 6, immagine 1 di 3 CyberPower UPS Battery Replacement: passo 6, immagine 2 di 3 CyberPower UPS Battery Replacement: passo 6, immagine 3 di 3
      • Insert the screw to secure the battery cover plate.
      • Tighten the screw with a Phillips #1 screwdriver.
      Chiedi a FixBot
      Aggiungi Commento
    7. CyberPower UPS Battery Replacement: passo 7, immagine 1 di 3 CyberPower UPS Battery Replacement: passo 7, immagine 2 di 3 CyberPower UPS Battery Replacement: passo 7, immagine 3 di 3
      • Plug system into the wall outlet.
      • Press the power button to turn on the unit.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
1Commento della guida
This guide is very educative and helpful.
Philip Saviour - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 13
Ultimi 7 giorni: 92
Ultimi 30 giorni: 454
Tutti i Tempi: 22,031
