Salta al contenuto principale
Cyber-shot DSC-H55 Lens Replacement
Cosa ti serve
  1. Cyber-shot DSC-H55 Lens Replacement, Removing Screws: passo 1, immagine 1 di 2 Cyber-shot DSC-H55 Lens Replacement, Removing Screws: passo 1, immagine 2 di 2
    • Use the Phillips #00 screwdriver to remove the two screws located on the right side of the camera.
  2. Cyber-shot DSC-H55 Lens Replacement, Removing Bottom Piece: passo 2, immagine 1 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing Bottom Piece: passo 2, immagine 2 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing Bottom Piece: passo 2, immagine 3 di 3
    • Use the Phillips #00 screwdriver to remove the three screws on the bottom of the camera.
    • Use the plastic opening tool to lift the cover containing the patent information off.
  3. Cyber-shot DSC-H55 Lens Replacement, Removing Left Side Piece: passo 3, immagine 1 di 2 Cyber-shot DSC-H55 Lens Replacement, Removing Left Side Piece: passo 3, immagine 2 di 2
    • Place the plastic opening tool in the crack between the metal circle and the black piece on the left.
    • Slide the black cover and lift to remove.
  4. Cyber-shot DSC-H55 Lens Replacement, Removing Newly Exposed Screws: passo 4, immagine 1 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing Newly Exposed Screws: passo 4, immagine 2 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing Newly Exposed Screws: passo 4, immagine 3 di 3
    • The first picture shows how the left side of the camera looks once we remove the side piece.
    • Use the Phillips #00 screwdriver to remove the two screws on this left side.
    • Flip your camera to the right side where we removed the first two screws.
    • Use the plastic opening tool into the crack and lift in order to loosen that side of the shell. Loosening one side makes removing the entire shell easier.
  5. Cyber-shot DSC-H55 Lens Replacement, Removing Back Shell: passo 5, immagine 1 di 2 Cyber-shot DSC-H55 Lens Replacement, Removing Back Shell: passo 5, immagine 2 di 2
    • Once the side is loose, apply a small amount of force to remove the shell.
    • Remove one side and then the other to avoid breaking any piece of the camera.
    • Keep the battery compartment open to make this step easier.
  6. Cyber-shot DSC-H55 Lens Replacement, Removing the Motherboard: passo 6, immagine 1 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing the Motherboard: passo 6, immagine 2 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing the Motherboard: passo 6, immagine 3 di 3
    • Removing the outer shell will expose the motherboard (the green chip).
    • Carefully grab the motherboard and flip it over.
    • Locate the ribbon wire protruding from the motherboard. Grip the wire as close to the white square as possible and slightly pull it to disconnect it from the wire.
  7. Cyber-shot DSC-H55 Lens Replacement, Detaching Metal around LCD Screen: passo 7, immagine 1 di 3 Cyber-shot DSC-H55 Lens Replacement, Detaching Metal around LCD Screen: passo 7, immagine 2 di 3 Cyber-shot DSC-H55 Lens Replacement, Detaching Metal around LCD Screen: passo 7, immagine 3 di 3
    • Remove the LCD Screen to separate the metal frame connecting the screen to the camera.
    • Gently pull the metal frame away, keeping in mind that the right end of the screen is attached by a ribbon wire.
    • Slowly remove the metal frame until it fully pops off.
  8. Cyber-shot DSC-H55 Lens Replacement, Detaching Ribbon Wires: passo 8, immagine 1 di 3 Cyber-shot DSC-H55 Lens Replacement, Detaching Ribbon Wires: passo 8, immagine 2 di 3 Cyber-shot DSC-H55 Lens Replacement, Detaching Ribbon Wires: passo 8, immagine 3 di 3
    • Flip the metal screen to be facing down. There will be a small black clip on the white connector that will allows the ribbon wire to be removed.
    • Carefully lift the black clip and slide the ribbon out in order to remove the LCD screen.
  9. Cyber-shot DSC-H55 Lens Replacement, Removing Top Shell: passo 9, immagine 1 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing Top Shell: passo 9, immagine 2 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing Top Shell: passo 9, immagine 3 di 3
    • Remove the Phillips #00 screw located at the top middle of the camera.
    • There is a ribbon wire on the top right. Make sure to disconnect the ribbon wire as you did in the previous step.
    • Slowly and carefully pull up.
  10. Cyber-shot DSC-H55 Lens Replacement, Removing Front Outer Shell: passo 10, immagine 1 di 1
    • Pull off front outer shell by pushing off from left side.
  11. Cyber-shot DSC-H55 Lens Replacement, Removing Ribbon Wires around Lens: passo 11, immagine 1 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing Ribbon Wires around Lens: passo 11, immagine 2 di 3 Cyber-shot DSC-H55 Lens Replacement, Removing Ribbon Wires around Lens: passo 11, immagine 3 di 3
    • Remove the two orange screws located under the lens.
    • Remove the plastic by grabbing the right side of the camera and pushing it away in order for the plastic to come out.
    • By removing the plastic, we can now easily remove the ribbon wires by lifting the black clip and sliding ribbon wire out. Use tweezers if necessary.
  12. Cyber-shot DSC-H55 Lens Replacement, Remove Lens: passo 12, immagine 1 di 2 Cyber-shot DSC-H55 Lens Replacement, Remove Lens: passo 12, immagine 2 di 2
    • Once the ribbons are detached, the lens is now completely detached from camera and can be replaced.
Conclusione
Jazmin Young
Membro da: 01/21/15
608 Reputazione
5 Guide realizzate
USF Tampa, Team 6-2, Brown Winter 2015 Membro di USF Tampa, Team 6-2, Brown Winter 2015
USFT-BROWN-W15S6G2
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,584
