Salta al contenuto principale
Cuisinart Griddler GR- 4N Button Spring Replacement
Cosa ti serve
  1. Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: passo 1, immagine 1 di 2 Cuisinart Griddler GR- 4N Button Spring Replacement, Cooking Surfaces: passo 1, immagine 2 di 2
    • Ensure device is turned unplugged, cooled down and clean before attempting any replacements.
    • Remove cooking plates by pushing in the tabs on each side of the plate at the same time.
  2. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 2, immagine 1 di 1
    • Remove the six 5.5mm Phillips #2 screws that secure the bottom heating coil to the device.
  3. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 3, immagine 1 di 1
    • Remove the four 30 mm Phillips #2 screws that secure the bottom heating apparatus.
  4. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 4, immagine 1 di 1
    • Remove the single 5.5 mm Phillips #2 screw next to center black button.
    • After removing the center screw the metal plate should be free to remove.
  5. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 5, immagine 1 di 2 Cuisinart Griddler GR- 4N Button Spring Replacement: passo 5, immagine 2 di 2
    • Lift the bottom heating apparatus up and remove large black center piece by pushing down on black button while sliding out.
    • Realign all surface and put device back together making sure all parts are lined up and heating surfaces are making contact.
    • The aligned parts will allow the cooking surfaces to work properly.
  6. Cuisinart Griddler GR- 4N Button Spring Replacement, Button Spring: passo 6, immagine 1 di 1
    • Depress one of the gray tabs on the side of the housing.
  7. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 7, immagine 1 di 1
    • Pull out the black button and the spring will also come out within it.
  8. Cuisinart Griddler GR- 4N Button Spring Replacement: passo 8, immagine 1 di 1
    • Pull out the spring, and insert the replacement spring making sure it is correctly aligned.
Conclusione
Altre 2 persone hanno completato questa guida.
Laine Aro
Membro da: 04/11/16
167 Reputazione
1 Guida realizzata
Cal Poly, Team 1-12, Maness Spring 2016 Membro di Cal Poly, Team 1-12, Maness Spring 2016
CPSU-MANESS-S16S1G12
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,701
