Salta al contenuto principale
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement
Cosa ti serve
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement, Internal Wiring: passo 1, immagine 1 di 1
    • Remove the four screws from the bottom of the processor with a Philips Screwdriver.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: passo 2, immagine 1 di 1
    • Remove the bottom casing of the processor.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: passo 3, immagine 1 di 1
    • If any wires are frayed, cut them off where they are connected by wire nuts.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: passo 4, immagine 1 di 1
    • Detach the wire nut from the other connected wires.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: passo 5, immagine 1 di 1
    • Replace the bad wire with a new one of the same gauge.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Internal Wiring Replacement: passo 6, immagine 1 di 1
    • Strip the new wire to the same length as the other wires and connect them to a wire nut.
Conclusione
Riley Carns
Membro da: 04/02/15
279 Reputazione
2 Guide realizzate
Cal Poly, Team 24-1, Lancaster Winter 2015 Membro di Cal Poly, Team 24-1, Lancaster Winter 2015
CPSU-LANCASTER-W15S24G1
1 Membro
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 972
