Salta al contenuto principale
Cuisinart DFP-14BCN Buttons Replacement
Cosa ti serve
  1. Cuisinart DFP-14BCN Buttons Replacement, Bowl: passo 1, immagine 1 di 3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: passo 1, immagine 2 di 3 Cuisinart DFP-14BCN Buttons Replacement, Bowl: passo 1, immagine 3 di 3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Buttons Replacement: passo 2, immagine 1 di 1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Buttons Replacement: passo 3, immagine 1 di 3 Cuisinart DFP-14BCN Buttons Replacement: passo 3, immagine 2 di 3 Cuisinart DFP-14BCN Buttons Replacement: passo 3, immagine 3 di 3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Buttons Replacement: passo 4, immagine 1 di 1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Buttons Replacement: passo 5, immagine 1 di 3 Cuisinart DFP-14BCN Buttons Replacement: passo 5, immagine 2 di 3 Cuisinart DFP-14BCN Buttons Replacement: passo 5, immagine 3 di 3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Buttons Replacement, Back Casing: passo 6, immagine 1 di 2 Cuisinart DFP-14BCN Buttons Replacement, Back Casing: passo 6, immagine 2 di 2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Buttons Replacement: passo 7, immagine 1 di 2 Cuisinart DFP-14BCN Buttons Replacement: passo 7, immagine 2 di 2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Buttons Replacement: passo 8, immagine 1 di 3 Cuisinart DFP-14BCN Buttons Replacement: passo 8, immagine 2 di 3 Cuisinart DFP-14BCN Buttons Replacement: passo 8, immagine 3 di 3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Buttons Replacement: passo 9, immagine 1 di 2 Cuisinart DFP-14BCN Buttons Replacement: passo 9, immagine 2 di 2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Buttons Replacement, Buttons: passo 10, immagine 1 di 3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: passo 10, immagine 2 di 3 Cuisinart DFP-14BCN Buttons Replacement, Buttons: passo 10, immagine 3 di 3
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Buttons Replacement: passo 11, immagine 1 di 2 Cuisinart DFP-14BCN Buttons Replacement: passo 11, immagine 2 di 2
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Buttons Replacement: passo 12, immagine 1 di 1
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Buttons Replacement: passo 13, immagine 1 di 3 Cuisinart DFP-14BCN Buttons Replacement: passo 13, immagine 2 di 3 Cuisinart DFP-14BCN Buttons Replacement: passo 13, immagine 3 di 3
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
Conclusione
Sonya Dick
Membro da: 10/05/16
352 Reputazione
3 Guide realizzate
Cal Poly, Team 10-3, Livingston Fall 2016 Membro di Cal Poly, Team 10-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G3
3 Membri
7 Guide realizzate
Un commento
Is there a source for replacing the button assembly?
BadMahoney - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,102
