Salta al contenuto principale
Cuisinart DCC-3200 Hot Plate Replacement
Cosa ti serve
  1. Cuisinart DCC-3200 Hot Plate Replacement, Hot Plate: passo 1, immagine 1 di 1
    • Unplug the device and flip it over so the bottom is facing upwards.
    • Remove the four screws.
    • Remove the bottom panel.
  2. Cuisinart DCC-3200 Hot Plate Replacement: passo 2, immagine 1 di 1
    • Remove the two screws from the silver brace.
  3. Cuisinart DCC-3200 Hot Plate Replacement: passo 3, immagine 1 di 2 Cuisinart DCC-3200 Hot Plate Replacement: passo 3, immagine 2 di 2
    • Use a spudger to wedge the red tube off of the metal.
    • Repeat this for the other side of the silver pipe deeper in the device.
  4. Cuisinart DCC-3200 Hot Plate Replacement: passo 4, immagine 1 di 1
    • Pick up the middle pipe and slide the hot plate out of its area.
    • Apply new thermal paste to the hot plate.
Conclusione
Altre 2 persone hanno completato questa guida.
Hamad Khan
Membro da: 03/04/16
385 Reputazione
3 Guide realizzate
5 Commenti
Where can one purchase the burner plate?
john Vet - Replica
Same question as John Vet
Bob Stimson - Replica
Did anyone ever get a response as to where a replacement could be purchased?
Joe Lubrant -
Did response provide required info?
Joe Lubrant - Replica
Same question: where can we purchase the burner plate?
Cresny - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 104
Tutti i Tempi: 4,851
