Salta al contenuto principale
Cuisinart DCC-1200 Coffee Carafe Handle Replacement
Cosa ti serve
  1. Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: passo 1, immagine 1 di 3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: passo 1, immagine 2 di 3 Cuisinart DCC-1200 Coffee Carafe Handle Replacement, Coffee Carafe Handle: passo 1, immagine 3 di 3
    • Wedge the metal spudger between the plug and the handle.
    • Carefully pry the plug with the metal spudger by applying pressure around the plug.
    • Too much pressure and prying can damage the plug.
  2. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 2, immagine 1 di 2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 2, immagine 2 di 2
    • Use the bit driver with the Phillips PH1 bit to remove the 27 millimeter long screw in the base of the handle.
  3. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 3, immagine 1 di 1
    • Lift up on and remove the lid from the carafe.
  4. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 4, immagine 1 di 2 Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 4, immagine 2 di 2
    • Position the metal spudger underneath the top cap of the handle.
    • Gently pry up to extract the upper assembly cap.
    • Pry carefully to prevent from causing aesthetic damage to upper assembly cap.
  5. Cuisinart DCC-1200 Coffee Carafe Handle Replacement: passo 5, immagine 1 di 1
    • Use the bit driver with the Phillips PH1 to remove the 5 millimeter screw in upper assembly of handle.
    • Remove handle by lifting straight up.
Conclusione
Altre 3 persone hanno completato questa guida.
UW Stout, Team S8-G1, Ogden Spring 2018 Membro di UW Stout, Team S8-G1, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G1
4 Membri
5 Guide realizzate
Un commento
I needed this guide after my spouse put the carafe in the dishwasher and the handle sloshed no matter how much I shook it. It turns out water is easily trapped under the top cap; even though there's a drain hole into the handle, it doesn't seem to want to drain. I've wiped it off and left it to dry completely before reassembling it.
Max - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 33
Tutti i Tempi: 3,729
