Salta al contenuto principale
Cuisinart DCC-1100 Hot Plate Replacement
Cosa ti serve
  1. Cuisinart DCC-1100 Hot Plate Replacement, Hot Plate: passo 1, immagine 1 di 1
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Hot Plate Replacement: passo 2, immagine 1 di 1
    • Remove the coffee pot and place the coffee maker upside down.
  3. Cuisinart DCC-1100 Hot Plate Replacement: passo 3, immagine 1 di 1
    • Remove the five 1.6mm Phillips #1 screws from the bottom panel.
  4. Cuisinart DCC-1100 Hot Plate Replacement: passo 4, immagine 1 di 1
    • Remove the bottom panel.
  5. Cuisinart DCC-1100 Hot Plate Replacement: passo 5, immagine 1 di 1
    • Remove the two 1.6mm Phillips #0 screws from the retaining bracket on the heating element.
  6. Cuisinart DCC-1100 Hot Plate Replacement: passo 6, immagine 1 di 1
    • Remove the retaining bracket and allow it to hang off of the heating element.
  7. Cuisinart DCC-1100 Hot Plate Replacement: passo 7, immagine 1 di 1
    • Remove the hot plate from the heating element.
    • New thermal paste should be applied at time of installation.
Conclusione
Altre 4 persone hanno completato questa guida.
Josh Harvey
Membro da: 01/25/18
889 Reputazione
4 Guide realizzate
USF Tampa, Team S20-G4, Passmore Spring 2018 Membro di USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Membri
7 Guide realizzate
13 Commenti
thank you for this informative display.
I have broken many expensive glass carafs for my cuisinart coffeemaker and finally purchased a cuisinart thermal caraf.
I do not need the hotplate to heat, so what do I do to stop the heating process?
I imagine I would need to remove one of the attached lines to the heating element, yes?
Thanks.
Luciano
luciano1213@msn.com
Luciano Muzzatti - Replica
Hi, Thanks for sharing this information. I have an older Krups coffee maker that still works great but the hot plate is warn. I cannot seem to find a replacement plate for any Krups coffee maker models. Any suggestions? Thanks!
Paulette Paglia - Replica
Josh
where do I buy the replacement hot plate?? I have the sis 15 coffeemaker and I have googled all over the place?? Thank u
linkev428 - Replica
Yes, where do you buy the part??
Kathy Johnston - Replica
Yes my question is where do you get the new hot plate? Any direction appreciated.
DougB - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 30
Tutti i Tempi: 6,167
