Salta al contenuto principale
Cuisinart DCC-1100 Drip Spring Replacement
Cosa ti serve
  1. Cuisinart DCC-1100 Drip Spring Replacement, Drip Spring: passo 1, immagine 1 di 1
    • Unplug the coffee maker.
  2. Cuisinart DCC-1100 Drip Spring Replacement: passo 2, immagine 1 di 1
    • Remove the coffee pot and open the top lid.
  3. Cuisinart DCC-1100 Drip Spring Replacement: passo 3, immagine 1 di 2 Cuisinart DCC-1100 Drip Spring Replacement: passo 3, immagine 2 di 2
    • Remove the basket filter holder.
  4. Cuisinart DCC-1100 Drip Spring Replacement: passo 4, immagine 1 di 1
    • Remove the basket filter from the holder.
  5. Cuisinart DCC-1100 Drip Spring Replacement: passo 5, immagine 1 di 1
    • Press up on the drip spring mechanism.
  6. Cuisinart DCC-1100 Drip Spring Replacement: passo 6, immagine 1 di 2 Cuisinart DCC-1100 Drip Spring Replacement: passo 6, immagine 2 di 2
    • While pressing up on the drip spring mechanism, remove the clear round plastic retainer holding the mechanism in place.
  7. Cuisinart DCC-1100 Drip Spring Replacement: passo 7, immagine 1 di 1
    • Remove the spring from the dripper.
Conclusione
Altre 8 persone hanno completato questa guida.
Josh Harvey
Membro da: 01/25/18
889 Reputazione
4 Guide realizzate
USF Tampa, Team S20-G4, Passmore Spring 2018 Membro di USF Tampa, Team S20-G4, Passmore Spring 2018
USFT-PASSMORE-S18S20G4
4 Membri
7 Guide realizzate
4 Commenti
Where do you find replacement springs?
Mrich - Replica
I have Cuisinart's Grind & Brew machine and it has an identical drip plug assembly. I measured carefully with a caliper and arrived at this spring size: 12 mm OD, 0.5 mm wire diameter, 30 mm free length. https://www.amazon.com/uxcell-0-5mmx12mm...
Chris Rockett -
My basket holder has thrown off the clear plastic retainer ring; is there a replacement part I can purchase?
Raymond Classen - Replica
When the basket holder came apart - the clear plasted retainer ring came off of mine, also. Can you just purchase this piece?
ncrenshaw4 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 52
Tutti i Tempi: 11,626
