Salta al contenuto principale
Cuisinart CPB-380 Power Cord Replacement
Cosa ti serve
  1. Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: passo 1, immagine 1 di 3 Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: passo 1, immagine 2 di 3 Cuisinart CPB-380 Power Cord Replacement, Cuisinart CPB-380 Disassembly: passo 1, immagine 3 di 3
    • Turn the device upside down.
    • Remove all four rubber feet by prying them out using the metal spudger.
    • Once the rubber feet have been removed, use the Phillips #2 screwdriver to remove all four 13mm screws.
  2. Cuisinart CPB-380 Power Cord Replacement: passo 2, immagine 1 di 2 Cuisinart CPB-380 Power Cord Replacement: passo 2, immagine 2 di 2
    • Remove the base from the body of the blender.
  3. Cuisinart CPB-380 Power Cord Replacement: passo 3, immagine 1 di 3 Cuisinart CPB-380 Power Cord Replacement: passo 3, immagine 2 di 3 Cuisinart CPB-380 Power Cord Replacement: passo 3, immagine 3 di 3
    • Remove the two 11mm screws securing the power cord using the Phillips #2 screwdriver.
    • Gently move the wire aside so that it is not in the way.
  4. Cuisinart CPB-380 Power Cord Replacement: passo 4, immagine 1 di 3 Cuisinart CPB-380 Power Cord Replacement: passo 4, immagine 2 di 3 Cuisinart CPB-380 Power Cord Replacement: passo 4, immagine 3 di 3
    • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
    • Gently remove the black cover.
    • Underneath, you will see a clear plastic cover that should be removed as well.
  5. Cuisinart CPB-380 Power Cord Replacement: passo 5, immagine 1 di 2 Cuisinart CPB-380 Power Cord Replacement: passo 5, immagine 2 di 2
    • Cut the zip tie that holds the black, blue, red, and yellow wires together.
    • Take care not to cut the wires.
  6. Cuisinart CPB-380 Power Cord Replacement, Power Cord: passo 6, immagine 1 di 2 Cuisinart CPB-380 Power Cord Replacement, Power Cord: passo 6, immagine 2 di 2
    • Remove the 2 black, yellow, and red wires from circuit board by push down on the tab to release and then pull up.
  7. Cuisinart CPB-380 Power Cord Replacement: passo 7, immagine 1 di 1
    • Pinch perpendicular to the flat surface and pull out the black wire.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 140
