Introduzione
Having problems powering-up your Cuisinart coffee-maker? Follow these instructions on how to replace Cuisinart CHW-12 power cord. This repair will only fix power issues directly related to the power cord. If the cord has been disconnected from the circuit board or severed a new power cord will be required to fix the issue. To successfully complete this guide you will need to know how to solder.
Cosa ti serve
Unplug the coffee-maker from the power source.
Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
Altre 2 persone hanno completato questa guida.
