Salta al contenuto principale
Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement
Cosa ti serve
  1. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement, Recoil Starter: passo 1, immagine 1 di 1
    • Remove the four screws from the hood of the lawnmower using a Phillips #0 screwdriver.
    Chiedi a FixBot
    Aggiungi Commento
  2. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 2, immagine 1 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 2, immagine 2 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 2, immagine 3 di 3
    • Remove the hood of the lawnmower by pulling up.
    Chiedi a FixBot
    Aggiungi Commento
  3. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 3, immagine 1 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 3, immagine 2 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 3, immagine 3 di 3
    • Using a wrench, remove the three nuts from the lawnmower’s defective recoil starter.
    Chiedi a FixBot
    Aggiungi Commento
  4. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 4, immagine 1 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 4, immagine 2 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 4, immagine 3 di 3
    • Remove the defective recoil starter by pulling up.
    Chiedi a FixBot
    Aggiungi Commento
  5. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 5, immagine 1 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 5, immagine 2 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 5, immagine 3 di 3
    • Place the new recoil starter in the lawnmower where the defective one was prior.
    Chiedi a FixBot
    Aggiungi Commento
  6. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 6, immagine 1 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 6, immagine 2 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 6, immagine 3 di 3
    • Tighten the new recoil starter onto the lawnmower with a wrench and the nuts you had removed earlier.
    Chiedi a FixBot
    Aggiungi Commento
  7. Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 7, immagine 1 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 7, immagine 2 di 3 Cub Cadet OHV 173cc/6.75 Recoil Starter Replacement: passo 7, immagine 3 di 3
    • Tighten the hood back onto the lawnmower with a Phillips #0 screwdriver and the four screws you had removed previously.
    • Make sure not to screw the hood on too tightly.
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Andres Dominguez
Membro da: 01/26/22
145 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 13
Ultimi 30 giorni: 79
Tutti i Tempi: 3,094
