Salta al contenuto principale
Crown Range Hood AFG-AC/SS Light Bulb Replacement
Cosa ti serve
  1. Crown Range Hood AFG-AC/SS Light Bulb Replacement, Light Bulb: passo 1, immagine 1 di 1
    • Check to make sure the the range hood is off.
    • To turn the range hood off, press the highlighted button.
    • The range hood should not emit any light or make any noise.
  2. Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 2, immagine 1 di 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #00 to remove the single screw securing the lightbulb panel to the ceiling of the range.
    • Too prevent both of the items from falling, hold onto the screw and panel during removal.
  3. Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 3, immagine 1 di 1
    • Slide the lightbulb cover out from the recessed area under the hood.
  4. Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 4, immagine 1 di 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 4, immagine 2 di 2
    • Twist the light bulb left to remove it from the range hood.
  5. Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 5, immagine 1 di 1
    • Use a cloth or a paper towel to clean the inside of the light bulb area.
    • Be sure to remove any debris or rust that might impair the installation of the new light bulb.
  6. Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 6, immagine 1 di 1
    • Guide the new lightbulb to the middle of the lightbulb base.
    • Install the new lightbulb with a twisting motion to the right.
    • Ensure the lightbulb is tightly secured onto the lightbulb base but don't overtighten.
  7. Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 7, immagine 1 di 2 Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 7, immagine 2 di 2
    • Place the screw back into the light bulb cover.
  8. Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 8, immagine 1 di 1
    • Set the light bulb cover back onto the light recess.
    • Use the Philips #00 screwdriver to tighten the single screw that holds the light bulb cover in place.
  9. Crown Range Hood AFG-AC/SS Light Bulb Replacement: passo 9, immagine 1 di 1
    • Turn the light on to make sure your repair was successful!
Linea Traguardo
Ken Cantago
Membro da: 01/30/23
169 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 30
Tutti i Tempi: 452
