Introduzione
Bushings are the rubber components in record players. Worn or loose bushings need to be replaced. This guide shows how to replace the bushings in the Crosley CR42 Player.
Strumenti
Parti
Nessuna parte specificata.
Turn the device around so the line out port faces you.
Remove the ten 12 mm screws with the Phillips screwdriver.
