Salta al contenuto principale
Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement
Cosa ti serve
  1. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Power Cord: passo 1, immagine 1 di 1
    • Remove the power cord from the wall outlet first, disconnecting power from the device.
  2. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: passo 2, immagine 1 di 1
    • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
  3. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: passo 3, immagine 1 di 2 Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: passo 3, immagine 2 di 2
    • Grasp the power cord input connector firmly with forefinger and thumb.
    • Without tugging, apply pulling force until the connector is free from device
  4. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Lid: passo 4, immagine 1 di 3 Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Lid: passo 4, immagine 2 di 3 Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Lid: passo 4, immagine 3 di 3
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
  5. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Sealing Ring: passo 5, immagine 1 di 1
    • Flip the lid over, exposing the underside and sealing ring.
  6. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: passo 6, immagine 1 di 2 Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: passo 6, immagine 2 di 2
    • Using a plastic opening tool, work your way in between the metal and sealing ring.
    • Continue to rotate and pry with the plastic opening tool until the sealing ring separates from the top.
Conclusione
Altre 2 persone hanno completato questa guida.
8 Commenti
Thank you for giving me the answer to how to be sure I assemble the seal correctly in the Crock Pot Express after we clean the cooker after I unboxed it. A video should be included with the Crock pot Express , it wwould help a lot. There were no pictures of the underside of the lid. The placement of gasket is very crucial to safety. I used a pressure scanner years ago. Iam impressed with the E6 flashing on the control panel. I do like the cooker overall!
gnag321 - Replica
Thank you very much for the advice. Now I can make sure I am placing the gasket in the cooker correctly. I used a pressure scanner/ cooker 30years ago! I like the e6 warning which was on the control panel to let me know that the pressure was not building up. I was able to let the steam off.
gnag321 - Replica
This gasket / seal seems very loose and ill fitting. Is this normal?
mark.e.betty - Replica
I agree it falls off mine on it’s own
gestep -
Where do I find the question & response to gnag321 ?
I have same question as mark.e.betty. I seem to have the seal in in the only way it will fit. Please advise as I love this machine & want to a lot more cooking. Tks
Rach Replogle - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 46
Tutti i Tempi: 9,349
