Salta al contenuto principale
Cricut Personal Logic Board Replacement
  1. Cricut Personal Logic Board Replacement, Access through the bottom: passo 1, immagine 1 di 2 Cricut Personal Logic Board Replacement, Access through the bottom: passo 1, immagine 2 di 2
    • Remove the 7 screws on the bottom. Then, wiggle the bottom panel free.
    • The logic board will be immediately exposed-- Take care not to mangle any of the connectors, or bump any capacitors.
    • The cartridge slot also comes out attached to the bottom panel.
  2. Cricut Personal Logic Board Replacement, Remove connectors: passo 2, immagine 1 di 2 Cricut Personal Logic Board Replacement, Remove connectors: passo 2, immagine 2 di 2
    • Remove all 8 connectors, plus the cartridge reader connector.
    • Refer to the images to remember where each connector plugs into.
  3. Cricut Personal Logic Board Replacement, Remove the board: passo 3, immagine 1 di 3 Cricut Personal Logic Board Replacement, Remove the board: passo 3, immagine 2 di 3 Cricut Personal Logic Board Replacement, Remove the board: passo 3, immagine 3 di 3
    • Remove the 4 screws holding in the logic board.
    • The power connector will be stuck. The power connector has a lip on it-- lift the back of the board up and out to free the lip.
Conclusione
Windey777
Membro da: 06/16/24
112 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 36
