Salta al contenuto principale
Cricut Maker Motherboard Replacement
Cosa ti serve
  1. Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: passo 1, immagine 1 di 3 Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: passo 1, immagine 2 di 3 Cricut Maker Motherboard Replacement, Cricut Maker Lid Replacement: passo 1, immagine 3 di 3
    • To remove the cover from the connecting joint, use an iFixit opening tool, and pry around the perimeter of the cover to release it.
    • Applying too much pressure to this can break it as it is very fragile.
    • There is some adhesive holding the cover, so it may take some patience and finesse to pry the cover off.
    • Remove the cover from the connecting joint and set it aside.
  2. Cricut Maker Motherboard Replacement: passo 2, immagine 1 di 2 Cricut Maker Motherboard Replacement: passo 2, immagine 2 di 2
    • Remove the four, 10 mm Torx TR8 security screws holding the lid in place.
  3. Cricut Maker Motherboard Replacement: passo 3, immagine 1 di 3 Cricut Maker Motherboard Replacement: passo 3, immagine 2 di 3 Cricut Maker Motherboard Replacement: passo 3, immagine 3 di 3
    • Turn the device around, so that the back is facing you.
    • Look for the small rectangles along the back of the device. For every two rectangles, there is one cylindrical connector in between the two.
    • Wedge one or two iFixit opening picks in the seam connecting the Top Door to the device, and use the iFixit opening tool to pry upwards along the seam.
    • These actions should reveal the cylindrical connectors.
  4. Cricut Maker Motherboard Replacement: passo 4, immagine 1 di 1
    • Press down on the lid.
    • Push the lid outwards to free it from the jointed clasps.
  5. Cricut Maker Motherboard Replacement, Front Door Replacement: passo 5, immagine 1 di 2 Cricut Maker Motherboard Replacement, Front Door Replacement: passo 5, immagine 2 di 2
    • Using your hands or an opening tool, remove the four foot pads covering four screws.
    • Use a Phillips #1 screwdriver to remove four 41 mm screws from the feet.
  6. Cricut Maker Motherboard Replacement: passo 6, immagine 1 di 3 Cricut Maker Motherboard Replacement: passo 6, immagine 2 di 3 Cricut Maker Motherboard Replacement: passo 6, immagine 3 di 3
    • Remove the seven screws (Four 8.5 mm screws, and three 12.5 mm screws) on the bottom of the device, this will allow you to remove the cover later on.
    • Use a Phillips #1 screwdriver to remove the four 8.5 mm screws from the bottom of the device.
    • Use a Phillips #0 screwdriver to remove the three 12.5 mm screws.
  7. Cricut Maker Motherboard Replacement: passo 7, immagine 1 di 3 Cricut Maker Motherboard Replacement: passo 7, immagine 2 di 3 Cricut Maker Motherboard Replacement: passo 7, immagine 3 di 3
    • Turn the device on its side.
    • To remove the seven 10 mm screws from the underside of the top of the device, use a Phillips #1 screwdriver with the flex extension.
  8. Cricut Maker Motherboard Replacement: passo 8, immagine 1 di 3 Cricut Maker Motherboard Replacement: passo 8, immagine 2 di 3 Cricut Maker Motherboard Replacement: passo 8, immagine 3 di 3
    • Lift the top case off of the base of the device.
    • After removing this cover, the internals of the device will be exposed.
  9. Cricut Maker Motherboard Replacement: passo 9, immagine 1 di 2 Cricut Maker Motherboard Replacement: passo 9, immagine 2 di 2
    • Use a Phillips #1 screwdriver to remove four 10 mm screws on the side of the device next to the motors.
    • Use a Phillips #1 screwdriver to remove the two 22 mm screws.
  10. Cricut Maker Motherboard Replacement: passo 10, immagine 1 di 3 Cricut Maker Motherboard Replacement: passo 10, immagine 2 di 3 Cricut Maker Motherboard Replacement: passo 10, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove two 10 mm screws. These are parallel to one another, one on either side of the machine.
    • Use a Phillips #1 screwdriver to remove two 8mm screws, these are also directly parallel to one another on either side of the machine.
  11. Cricut Maker Motherboard Replacement: passo 11, immagine 1 di 2 Cricut Maker Motherboard Replacement: passo 11, immagine 2 di 2
    • Unplug the bundled connector from the motor on both sides of the machine. To to avoid damage, coax the connector out of the socket gently using a spudger.
  12. Cricut Maker Motherboard Replacement: passo 12, immagine 1 di 2 Cricut Maker Motherboard Replacement: passo 12, immagine 2 di 2
    • Using a Phillips #1 screwdriver, remove one 10 mm screw from both sides of the machine. This will release wires that are screwed into the sides of device.
    • Once the screws are removed and wires detached, the main body can be lifted off the base, and set aside.
  13. Cricut Maker Motherboard Replacement: passo 13, immagine 1 di 3 Cricut Maker Motherboard Replacement: passo 13, immagine 2 di 3 Cricut Maker Motherboard Replacement: passo 13, immagine 3 di 3
    • Remove a total of seven 10 mm screws from the underside of the door.
    • One side of the base has two 10mm screws.
    • The other side of the base has five 10 mm screws.
  14. Cricut Maker Motherboard Replacement: passo 14, immagine 1 di 3 Cricut Maker Motherboard Replacement: passo 14, immagine 2 di 3 Cricut Maker Motherboard Replacement: passo 14, immagine 3 di 3
    • Pry the door from hinges using an iFixit opening tool.
    • Lift upwards and towards you, to remove the door from the hinges.
  15. Cricut Maker Motherboard Replacement, Motherboard Replacement: passo 15, immagine 1 di 3 Cricut Maker Motherboard Replacement, Motherboard Replacement: passo 15, immagine 2 di 3 Cricut Maker Motherboard Replacement, Motherboard Replacement: passo 15, immagine 3 di 3
    • Use a Phillips #2 screwdriver to remove the five 7 mm screws from the motherboard.
  16. Cricut Maker Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove the gray electrical tape from the cables.
  17. Cricut Maker Motherboard Replacement: passo 17, immagine 1 di 2 Cricut Maker Motherboard Replacement: passo 17, immagine 2 di 2
    • Unplug both cables from the corners of the motherboard by pulling them upwards from the base of the connectors.
  18. Cricut Maker Motherboard Replacement: passo 18, immagine 1 di 2 Cricut Maker Motherboard Replacement: passo 18, immagine 2 di 2
    • Gently slide the motherboard out from USB port slot to remove it from the device.
Conclusione
Altre 4 persone hanno completato questa guida.
6 Commenti
So do you sell the motherboard or know where it buy one for cricut cxpl301
David Washington - Replica
I too am looking for a replacement board. It was suggested to me that I could contact one of the pcb repair companies. For a fee, they will either check and repair your board or they will copy and print a new board and mail it back to you. You have to send in your board for them to check and copy though. So I guess reputation and reviews would be priority. It would suck to send our boards off and never receive a new one or the old one. :-/.
Jennifer Daniels -
Cricut does not sell parts. Cricut does not do repairs.
B·Ware - Replica
sooooo, theres no place to get parts? thats stupid...might as well just through it away then...
Kirk Serbian - Replica
Bonjour pourriez vous nous dire où trouver la carte mère svp
Magali Magnier - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 73
Ultimi 30 Giorni: 205
Tutti i Tempi: 8,412
