Salta al contenuto principale
Creative Ziio 7" Motherboard Replacement
Cosa ti serve
  1. Creative Ziio 7" Motherboard Replacement, Back Panel: passo 1, immagine 1 di 3 Creative Ziio 7" Motherboard Replacement, Back Panel: passo 1, immagine 2 di 3 Creative Ziio 7" Motherboard Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" Motherboard Replacement, Motherboard: passo 2, immagine 1 di 3 Creative Ziio 7" Motherboard Replacement, Motherboard: passo 2, immagine 2 di 3 Creative Ziio 7" Motherboard Replacement, Motherboard: passo 2, immagine 3 di 3
    • Remove the copper plate covering the motherboard by desoldering the ten solder points.
    • The solder point in the bottom right corner is marked but hidden by the soldering iron.
  3. Creative Ziio 7" Motherboard Replacement: passo 3, immagine 1 di 2 Creative Ziio 7" Motherboard Replacement: passo 3, immagine 2 di 2
    • Remove the adhesive tape covering the three wires connected to the motherboard.
    • Desolder the solder points connecting the wires to the motherboard.
  4. Creative Ziio 7" Motherboard Replacement: passo 4, immagine 1 di 3 Creative Ziio 7" Motherboard Replacement: passo 4, immagine 2 di 3 Creative Ziio 7" Motherboard Replacement: passo 4, immagine 3 di 3
    • Disconnect the ribbon cable that is attached underneath the copper plate.
    • Disconnect the other ribbon cable that is connected next the copper plate in the corner of the circuit board.
  5. Creative Ziio 7" Motherboard Replacement: passo 5, immagine 1 di 2 Creative Ziio 7" Motherboard Replacement: passo 5, immagine 2 di 2
    • Remove the four 4mm Philips #00 screws holding the motherboard to the casing.
    • The copper plate will be removed by now. However, the picture does not show this.
  6. Creative Ziio 7" Motherboard Replacement: passo 6, immagine 1 di 2 Creative Ziio 7" Motherboard Replacement: passo 6, immagine 2 di 2
    • Lift up the motherboard.
    • A mesh-looking strip on the left side will be connected to the bottom of the motherboard.
    • Remove the tape on top of the strip and use tweezers or pliers to pull on the strip to unplug it.
  7. Creative Ziio 7" Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the red and black wires with a soldering iron that are located underneath the motherboard.
    • Do not cut or damage the wires in the process. They will be needed for the new motherboard.
  8. Creative Ziio 7" Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the old motherboard and dispose of it resposibly.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 14-10, Maness Spring 2013 Membro di Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Membri
13 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,191
