Salta al contenuto principale
Creative Ziio 7" LCD Screen Replacement
Cosa ti serve
  1. Creative Ziio 7" LCD Screen Replacement, Back Panel: passo 1, immagine 1 di 3 Creative Ziio 7" LCD Screen Replacement, Back Panel: passo 1, immagine 2 di 3 Creative Ziio 7" LCD Screen Replacement, Back Panel: passo 1, immagine 3 di 3
    • Remove the back panel by using the plastic opening tool to carefully pry around the panel's edges.
    • The volume control button and the top power button may fall out during this step.
  2. Creative Ziio 7" LCD Screen Replacement, LCD Screen: passo 2, immagine 1 di 1
    • Remove the four 3mm Philips #00 screws around the large silver battery.
  3. Creative Ziio 7" LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the four 4mm Philips #00 screws on the edges of the circuit board.
  4. Creative Ziio 7" LCD Screen Replacement: passo 4, immagine 1 di 3 Creative Ziio 7" LCD Screen Replacement: passo 4, immagine 2 di 3 Creative Ziio 7" LCD Screen Replacement: passo 4, immagine 3 di 3
    • Remove the ribbon cable from the exposed side of circuit board near the headphone jack.
    • Carefully lift up the circuit board on the detached side.
    • There is another ribbon cable attached to the underside of the circuit board.
    • Disconnect the second ribbon cable by pulling the end of the ribbon from its housing on the circuit board with tweezers.
    • The circuit board is extremely delicate. Move carefully and don't rush on this step!
  5. Creative Ziio 7" LCD Screen Replacement: passo 5, immagine 1 di 1
    • On the opposite end of the device: Remove the ribbon cable in between the speakers at the end of the battery.
  6. Creative Ziio 7" LCD Screen Replacement: passo 6, immagine 1 di 1
    • There are three additional 3mm Philips #00 screws underneath the circuit board that need to be removed.
    • Now, remove the battery and circuit board with the LCD attached and turn it over so the screen is facing upwards.
  7. Creative Ziio 7" LCD Screen Replacement: passo 7, immagine 1 di 2 Creative Ziio 7" LCD Screen Replacement: passo 7, immagine 2 di 2
    • Carefully pry the thin, metal frame from around the LCD screen.
    • The frame is extremely thin! Take your time when removing it to avoid bending or deforming it.
  8. Creative Ziio 7" LCD Screen Replacement: passo 8, immagine 1 di 1
    • Carefully remove the black LCD screen.
Conclusione
Altre 2 persone hanno completato questa guida.
Kyle
Membro da: 04/16/13
111 Reputazione
2 Guide realizzate
Cal Poly, Team 14-10, Maness Spring 2013 Membro di Cal Poly, Team 14-10, Maness Spring 2013
CPSU-MANESS-S13S14G10
4 Membri
13 Guide realizzate
2 Commenti
Where can I buy Creative Ziio 7" LCD Scren?
CoolBlazer - Replica
i need LCD Creative Labs ZIIO 7 Inch Tablet, where i can buy?... please help me... thx before...
irawansandra -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,352
