Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
This guide will show you how to access the motherboard and speaker on your device.
  1. Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device. Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device. Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
    • Remove 2 screws (2.5 mm) on the top of the device using Phillips #0.
  3. Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
    • Remove 2 screws (2.5 mm) on the bottom of the device using a Phillips #0.
  4. Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen. When the cover has been lifted off the screen, use your hands to remove it from the device. The button pad may fall off when the cover is removed.
    • Use a spudger to get between the cover and the screen. Carefully lift the cover off of the screen without putting too much pressure on the screen.
    • When the cover has been lifted off the screen, use your hands to remove it from the device.
    • The button pad may fall off when the cover is removed.
  5. Use a spudger to separate the metal tabs that hold the screen in place on the right side. The screen is still attached underneath with two ribbon cables.  Lift it very carefully. The screen is still attached underneath with two ribbon cables.  Lift it very carefully.
    • Use a spudger to separate the metal tabs that hold the screen in place on the right side.
    • The screen is still attached underneath with two ribbon cables. Lift it very carefully.
  6. Put the screen face down so you can see where the ribbon cables are attached.
    • Put the screen face down so you can see where the ribbon cables are attached.
    • Remove the red sticker that covers the ribbon cable connections.
  7. Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
    • Use a plastic opening tool to get underneath the black flap on the larger ribbon cable connection and lift it.
  8. Use a spudger to slide the two small gray tabs away from the ribbon cable connection. Remove the screen from the device. Remove the screen from the device.
    • Use a spudger to slide the two small gray tabs away from the ribbon cable connection.
    • Remove the screen from the device.
  9. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  10. Peel the orange sticker off of the motherboard.
    • Peel the orange sticker off of the motherboard.
  11. Lift the keypad from the left side and use tweezers to slide it out to the left. Lift the keypad from the left side and use tweezers to slide it out to the left.
    • Lift the keypad from the left side and use tweezers to slide it out to the left.
  12. Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection. Remove the ribbon cable from the keypad.
    • Use a small flat head screw driver to slide the white tabs away from the ribbon cable connection.
    • Remove the ribbon cable from the keypad.
  13. Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  14. Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary. Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  15. Carefully pull the back cover off of the rest of the device. The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces. The USB input cover on the bottom of the device may also fall off.
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
  16. Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0. Lift the metal cover off.
    • Remove 4 screws (3.5 mm) on the metal cover with a Phillips #0.
    • Lift the metal cover off.
  17. Lift the white and black ribbon connection off of the motherboard. The hard drive can now be removed. The hard drive can now be removed.
    • Lift the white and black ribbon connection off of the motherboard.
    • The hard drive can now be removed.
  18. Remove 2 screws (3.5 mm) on the black compact flash input using a Phillips #0. Remove 2 screws (3.5 mm) on the black compact flash input using a Phillips #0. Remove 2 screws (3.5 mm) on the black compact flash input using a Phillips #0.
    • Remove 2 screws (3.5 mm) on the black compact flash input using a Phillips #0.
  19. Use a small flat head screwdriver to bend the plastic tab holding the compact flash input in place.
    • Use a small flat head screwdriver to bend the plastic tab holding the compact flash input in place.
    • The compact flash input should pop off easily, be careful not to break it.
  20. Turn the device over so the side where the screen was is facing up.
    • Turn the device over so the side where the screen was is facing up.
    • Push on the motherboard lightly to separate it from the casing.
  21. Turn the device over again and pull on the motherboard very lightly. The speaker will be covered in a black glue and you must cut through this in order to remove the motherboard.
    • Turn the device over again and pull on the motherboard very lightly.
    • The speaker will be covered in a black glue and you must cut through this in order to remove the motherboard.
  22. Turn the speaker on its side so it can fit through the casing and the motherboard can be removed.
    • Turn the speaker on its side so it can fit through the casing and the motherboard can be removed.
  23. You have now removed the motherboard. Speaker
    • You have now removed the motherboard.
    • Speaker
Conclusione
Altre 2 persone hanno completato questa guida.
Tim Wilson
Membro da: 11/04/2013
128 Reputazione
6 Guide realizzate
Cal Poly, Team 17-2, Regan Spring 2013 Membro di Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Membri
8 Guide realizzate
does the creative vision W have a 44 pin hard disk connector on the main board same as creative vision m has?
leohobb - Replica
If the main board on vision w hard disk connector has 44 pins as vision m has but the vision w has a zif 40 pin ribbon in to the hard disk.it make me belive that it is possible to use a zif connector style hard disk on vision M to with the hard disk cable from vision w?Or does i miss something?i want to try to use a 1.8 hard disk with around 100 GB capacity on vision M if possible
leohobb - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 820
