Salta al contenuto principale
Creative Zen Vision M Screen Replacement
Cosa ti serve
  1. Creative Zen Vision M Screen Replacement, Opening the top: passo 1, immagine 1 di 2 Creative Zen Vision M Screen Replacement, Opening the top: passo 1, immagine 2 di 2
    • Pop off the top plastic on the device with a flat tool like a flathead screwdriver.
    • Unscrew and remove the two exposed Phillips head screws.
  2. Creative Zen Vision M Screen Replacement, Opening the device: passo 2, immagine 1 di 2 Creative Zen Vision M Screen Replacement, Opening the device: passo 2, immagine 2 di 2
    • Work your way around the recess of the device with a flat tool like a flathead screwdriver.
    • Don't try attempt to open it from the recess between the buttons and the device.
  3. Creative Zen Vision M Screen Replacement, Disconnecting the battery: passo 3, immagine 1 di 3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: passo 3, immagine 2 di 3 Creative Zen Vision M Screen Replacement, Disconnecting the battery: passo 3, immagine 3 di 3
    • Disconnect the wire from the bottom device.
    • Handle with care as the wires tend to disconnect easily.
  4. Creative Zen Vision M Screen Replacement, Disconnecting the hard drive: passo 4, immagine 1 di 1
    • In the top right corner, pull the black foam square off to separate the hard drive from the screen.
    • Handle with care as the hard drive also comes off easily.
  5. Creative Zen Vision M Screen Replacement, Unscrewing from the mother board: passo 5, immagine 1 di 1
    • Unscrew the seven screws placed around the mother board.
    • You will need a one millimeter Phillips head screwdriver.
    • The screws are small, so keep them safely.
  6. Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: passo 6, immagine 1 di 3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: passo 6, immagine 2 di 3 Creative Zen Vision M Screen Replacement, Disconnecting the screen from the motherboard: passo 6, immagine 3 di 3
    • Flip your device upside down so that the motherboard will loosen.
    • Detach the connector from the motherboard.
  7. Creative Zen Vision M Screen Replacement, Removing the screen: passo 7, immagine 1 di 2 Creative Zen Vision M Screen Replacement, Removing the screen: passo 7, immagine 2 di 2
    • Tilt the screen diagonally. Separate the screen and motherboard from the device frame.
    • Lift the light gray flap to detach the screen from the motherboard.
  8. Creative Zen Vision M Screen Replacement, Seperating the digital display: passo 8, immagine 1 di 2 Creative Zen Vision M Screen Replacement, Seperating the digital display: passo 8, immagine 2 di 2
    • Separate the clear screen frame from the digital display.
Conclusione
Kirstie G
Membro da: 10/12/16
488 Reputazione
4 Guide realizzate
Texas Tech, Team 12-1, Bennett Fall 2016 Membro di Texas Tech, Team 12-1, Bennett Fall 2016
TTU-BENNETT-F16S12G1
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,635
