Salta al contenuto principale
Creative Zen V Plus Logic Board Replacement
Cosa ti serve
  1. Creative Zen V Plus Logic Board Replacement, Prerequisite Only: passo 1, immagine 1 di 1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Logic Board Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Logic Board Replacement: passo 3, immagine 1 di 1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Logic Board Replacement: passo 4, immagine 1 di 2 Creative Zen V Plus Logic Board Replacement: passo 4, immagine 2 di 2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Logic Board Replacement: passo 5, immagine 1 di 1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Logic Board Replacement: passo 6, immagine 1 di 3 Creative Zen V Plus Logic Board Replacement: passo 6, immagine 2 di 3 Creative Zen V Plus Logic Board Replacement: passo 6, immagine 3 di 3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Logic Board Replacement, Logic Board: passo 7, immagine 1 di 1
    • Unplug the logic board from the battery. Replace the logic board with your new logic board and reassemble your device.
Conclusione
Joel Ng
Membro da: 10/19/16
239 Reputazione
1 Guida realizzata
IUPUI, Team 2-5, Baechle Fall 2016 Membro di IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 466
