Salta al contenuto principale
Creative Nomad Jukebox Zen Display Screen Replacement
Cosa ti serve
  1. Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: passo 1, immagine 1 di 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: passo 1, immagine 2 di 3 Creative Nomad Jukebox Zen Display Screen Replacement, Front and Back Cover: passo 1, immagine 3 di 3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Display Screen Replacement: passo 2, immagine 1 di 3 Creative Nomad Jukebox Zen Display Screen Replacement: passo 2, immagine 2 di 3 Creative Nomad Jukebox Zen Display Screen Replacement: passo 2, immagine 3 di 3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Display Screen Replacement, Screen Cover: passo 3, immagine 1 di 1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Display Screen Replacement, Display Screen: passo 4, immagine 1 di 1
    • Using the plastic opening tool to pop the metal tab holding the battery in place.
    • By breaking the sticker, it could void your warranty
  5. Creative Nomad Jukebox Zen Display Screen Replacement: passo 5, immagine 1 di 2 Creative Nomad Jukebox Zen Display Screen Replacement: passo 5, immagine 2 di 2
    • Use the spudger tool to unclip the screens wiring pigtail clipped into the motherboard.
  6. Creative Nomad Jukebox Zen Display Screen Replacement: passo 6, immagine 1 di 2 Creative Nomad Jukebox Zen Display Screen Replacement: passo 6, immagine 2 di 2
    • Use soldering iron to melt the solder used to hold the display screen to the motherboard.
    • Using soldering gun with care as it becomes extremely hot and can cause burns.
  7. Creative Nomad Jukebox Zen Display Screen Replacement: passo 7, immagine 1 di 1
    • Using the spudger tool, gently pry up the corners of the display screen to remove it.
Conclusione
Austin Shaw
Membro da: 03/08/17
101 Reputazione
1 Guida realizzata
IUPUI, Team S4-G5, Baechle Spring 2017 Membro di IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Membri
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 697
