Salta al contenuto principale
Creative Nomad II Headphone Jack Replacement
Cosa ti serve
  1. Creative Nomad II Headphone Jack Replacement, Battery: passo 1, immagine 1 di 1
    • Using your thumb, slide down and remove the battery cover.
  2. Creative Nomad II Headphone Jack Replacement: passo 2, immagine 1 di 1
    • Using your index finger, remove the old AA battery.
    • Install the new AA battery.
  3. Creative Nomad II Headphone Jack Replacement, Smart Media Card: passo 3, immagine 1 di 1
    • Slide down the eject button.
    • Pull out the old SmartMedia Card.
    • Insert the new SmartMedia Card.
    • The notched corner of the SmartMedia card should go in the top left corner.
  4. Creative Nomad II Headphone Jack Replacement, Back Cover: passo 4, immagine 1 di 1
    • Using a Phillips #00 Screwdriver, remove the two 7.5 mm screws located on the left and right side of the back cover, respectively.
  5. Creative Nomad II Headphone Jack Replacement: passo 5, immagine 1 di 1
    • Remove the back cover of the Nomad II.
    • Remove the following items located on the left and right side of the device:
    • The rubber USB port cover
    • The plastic lock/unlock switch cover
    • The buttons located on the left side of the device
  6. Creative Nomad II Headphone Jack Replacement, Battery Compartment: passo 6, immagine 1 di 1
    • Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located in the bottom corners of the battery compartment.
  7. Creative Nomad II Headphone Jack Replacement: passo 7, immagine 1 di 1
    • Using your fingers, carefully remove the battery compartment.
  8. Creative Nomad II Headphone Jack Replacement, Circuit Boards: passo 8, immagine 1 di 1
    • Using a Phillips #00 Screwdriver, remove the two 5.5 mm screws located on the left and right edges of the circuit board.
  9. Creative Nomad II Headphone Jack Replacement: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of tweezers, carefully remove the metal loop attached to the circuit board from its plastic case on the left side of the battery compartment.
  10. Creative Nomad II Headphone Jack Replacement: passo 10, immagine 1 di 1
    • Pull out the circuit boards.
    • When reinserting the circuit boards, press the front face of the boards into the device case until you hear a click.
  11. Creative Nomad II Headphone Jack Replacement: passo 11, immagine 1 di 1
    • Position the circuit boards with the USB port facing up.
    • Gently separate the circuit boards.
  12. Creative Nomad II Headphone Jack Replacement, Headphone Jack: passo 12, immagine 1 di 1
    • Using a pair of tweezers, gently lift and peel back the thin copper film covering the headphone jack.
    • Only peel back the film enough to expose the headphone jack.
    • Completely removing the copper film can damage the device.
  13. Creative Nomad II Headphone Jack Replacement: passo 13, immagine 1 di 1
    • Gently remove the black adhesive tape from the underside of the headphone jack.
  14. Creative Nomad II Headphone Jack Replacement: passo 14, immagine 1 di 1
    • Desolder the four solder joints securing the headphone jack.
    • Remove the old headphone jack.
    • Install the new headphone jack.
Conclusione
Cal Poly, Team 9-2, Regan Winter 2012 Membro di Cal Poly, Team 9-2, Regan Winter 2012
CPSU-REGAN-W12S9G2
5 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,539
