Introduzione
This guide's intention is to solve problems like your filament grinding in your Creality Ender 3 Pro. This is often caused by the extruder arm applying too much pressure (or too little) to the filament. To complete this guide, you should have a replacement extruder ready for your extruder mechanism, which you can purchase online.
All the tools you need are a 2.5 mm hex key, a 8 mm wrench, and around 10-15 minutes of your time!
Cosa ti serve
Press the knob to enter the marlin LCD menu and turn it to navigate between the options.
Navigate to Temperature > Nozzle.
Adjust the nozzle temperature by turning the knob and confirm by pressing it.
Wait until the current temperature (bottom) matches the target temperature (top).
Press down on the extruder lever arm and pull out the loaded filament.
Use a 8 mm wrench or some pliers to unscrew the PTFE tube from the extruder mechanism.
Don't forget to recalibrate your E steps!
