Salta al contenuto principale
Creality Ender 3 Bracket Plate of Y-Axis Motor Replacement
Cosa ti serve
  1. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement, Bracket Plate of Y-Axis Motor: passo 1, immagine 1 di 1
    • Place the bed plate in the middle of your Ender 3. Do this manually by gently pushing it to the middle.
  2. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 2, immagine 1 di 2 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 2, immagine 2 di 2
    • Or alternatively, place the bed in the center by turning your Ender 3 on.
  3. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 3, immagine 1 di 3 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 3, immagine 2 di 3 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 3, immagine 3 di 3
    • Turn on the printer, and click the button to the screen shown in the photo.
    • Rotate the button clockwise to "Prepare".
    • Rotate the button clockwise to AutoHome. This should set your bedplate to 0 on both X & Y axes.
  4. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 4, immagine 1 di 1
    • Unplug the wire that is connected to the Y motor.
  5. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 5, immagine 1 di 1
    • Remove the two M4*20 screws from the back end of the Y-axis bar using an 8 mm Allen Wrench. The side of the display should be facing you.
  6. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 6, immagine 1 di 1
    • Remove the four M3*6 screws that are attaching the motor to the Y-axis motor using an 8 mm Allen Wrench.
  7. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 7, immagine 1 di 1
    • Buy a new bracket with the same brand (depending on the severity of the bend of the bracket) or straighten the metal on your own.
  8. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 8, immagine 1 di 2 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 8, immagine 2 di 2
    • If you choose to fix it on your own, slip the bracket in between a workshop bench clamp. Apply enough pressure between two thick blocks of metal to straighten it.
    • Use vise-grips to aid in stabilizing the metal as you force the metal to straighten.
  9. Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 9, immagine 1 di 2 Creality Ender 3  Bracket Plate of Y-Axis Motor Replacement: passo 9, immagine 2 di 2
    • Repeat, Steps 6-11 in reverse to put the bracet back on the Y motor and back on the Ender 3.
    • Turn on Ender 3 to see if you did it correctly. Try to also print something too!
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 70
Tutti i Tempi: 1,812
