Salta al contenuto principale
Creality CR-20 X Gantry Alignment
  1. Creality CR-20 X Gantry Alignment, X Gantry Alignment: passo 1, immagine 1 di 3 Creality CR-20 X Gantry Alignment, X Gantry Alignment: passo 1, immagine 2 di 3 Creality CR-20 X Gantry Alignment, X Gantry Alignment: passo 1, immagine 3 di 3
    • The CR-20 Pro has solid bed mounts. If any X axis gantry alignment is needed, you can use the "nozzle to bed" distance to check.
    • With M2.5 hex, loosen the 2 button head screws on the back side/ right of the X/Z Bracket.
    • If the right side is too low and needs to go up, squeeze the bracket and rail together while tightening the button head screws.
    • If the right side is high and needs to be lowered, you will squeeze the bottom wheel against the X rail while tightening.
    • When properly adjusted, the nozzle will be the same distance from the bed from left to right.
    • In some cases, it is necessary to do this process on the left side (near extruder motor) but requires partial disassembly of the machine.
Conclusione
Tiny Machines 3D
Membro da: 11/16/19
3.019 Reputazione
14 Guide realizzate
Tiny Machines 3D Membro di Tiny Machines 3D
Community
5 Membri
41 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,329
