Introduzione
This guide will show you how to replace or install dampers on the Creality CR-10S 3D printer in order to provide noise reduction while printing. The dampeners are made of rubber material; this will separate the metal frame of the motor from contacting the metal bracket of the 3D printer, greatly reducing noise.
It is important to note that this process can be replicated for all CR-10 devices with similar stepper motors.
Before You Begin
- Ensure that there is no power flowing through the unit by disconnecting the power cable.
- Read through the guide to familiarize yourself with the process.
- Know the location of the components. The image above shows the x-axis components in red and the y-axis components in blue.
- Remember to be gentle with the hardware. Putting too much pressure turning a screw may strip it, making it difficult to remove in the future.
Strumenti
Ricambi
Using the 3mm Allen key, remove the two 3mm Allen head screws on either side of the y-axis bracket to undo the tensioner. Push forward to give the belt slack.
