Introduzione
If the crayon maker is not closing properly, check the position of the plastic arm. Adjust the plastic arm if it is out of place. Replace the arm if it is broken.
Parti
Nessuna parte richiesta.
Press the green arm away from the melting tray. Remove the melting tray.
  • Press the green arm away from the melting tray. Remove the melting tray.
  • Pop the metal arms out of the green pivot support.
Aggiungi Commento
Remove the 2 screws (.75cm in length) currently securing the metal melting tray  with a Phillips #2 screwdriver.
  • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
Aggiungi Commento
  • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
Aggiungi Commento
  • Flip the crayon maker.
  • Remove six screws (2 cm in length) with a spanner.
  • Remove the green base plate and set it aside.
Aggiungi Commento
  • Locate the clear plastic arm inside the control box.
Aggiungi Commento
  • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
  • If the plastic arm is broken, contact Crayola for replacement parts.
Aggiungi Commento
  • Remove the green base from the crayon maker and set aside.
  • Locate the clear box.
Aggiungi Commento
  • There are four screws (circled in red) that need to be removed with a Phillips #00 Precision screwdriver.
Aggiungi Commento
  • Remove five screws (1.5 cm in length) using a Phillips #00 Precision screwdriver and open the clear plastic box.
Aggiungi Commento
  • The plastic arm should be positioned as shown in the figure. Adjust the arm's position if necessary.
  • If the plastic arm is broken, contact Crayola for a replacement arm.
Aggiungi Commento
Conclusione
Melissa
Membro da: 10/10/2014
210 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 431
