Salta al contenuto principale
Crayola Crayon Maker Light Bulb Removal and Replacement
Cosa ti serve
  1. Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: passo 1, immagine 1 di 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: passo 1, immagine 2 di 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: passo 1, immagine 3 di 3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: passo 2, immagine 1 di 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: passo 2, immagine 2 di 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: passo 2, immagine 3 di 3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: passo 3, immagine 1 di 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: passo 3, immagine 2 di 3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: passo 3, immagine 3 di 3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
Linea Traguardo
Heidi Clarke
Membro da: 09/21/14
222 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 32
Tutti i Tempi: 6,513
