Salta al contenuto principale
Crank Arms Replacement
Cosa ti serve
  1. Crank Arms Replacement, Crank Arms: passo 1, immagine 1 di 2 Crank Arms Replacement, Crank Arms: passo 1, immagine 2 di 2
    • Take cap off the crank arm with flat head screw driver. It should just pop off.
  2. Crank Arms Replacement: passo 2, immagine 1 di 2 Crank Arms Replacement: passo 2, immagine 2 di 2
    • Use a socket wrench to take out the main bolt.
  3. Crank Arms Replacement: passo 3, immagine 1 di 1
    • Attach the crank puller to the threads on the crank arm, hand tighten it in until it bottoms out.
    • Be careful not to strip the aluminum threading of the crank arm with the steel threading of the crank puller. Don't force anything.
  4. Crank Arms Replacement: passo 4, immagine 1 di 1
    • Use wrench to tighten the free end of the crank arm, pulling the crank arm off the bike.
  5. Crank Arms Replacement: passo 5, immagine 1 di 3 Crank Arms Replacement: passo 5, immagine 2 di 3 Crank Arms Replacement: passo 5, immagine 3 di 3
    • Clean the bottom bracket axle, crank arm, and sprockets with a rag.
  6. Crank Arms Replacement: passo 6, immagine 1 di 1
    • Slide the new crank arm on the the tapered square of the bottom bracket axle.
  7. Crank Arms Replacement: passo 7, immagine 1 di 2 Crank Arms Replacement: passo 7, immagine 2 di 2
    • Use a socket wrench to tighten the main bolt.
    • It's easy to cross thread the aluminum crank arm with the steel crank puller. Be very careful to thread properly.
  8. Crank Arms Replacement: passo 8, immagine 1 di 1
    • Replace the cap.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
aaron thielk
Membro da: 10/10/10
1.882 Reputazione
5 Guide realizzate
Cal Poly, Team 5-13, Maness Fall 2010 Membro di Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
4 Membri
17 Guide realizzate
4 Commenti
Hello, hope you can help
The resistance on my bike when going up hills is crazy I have take to a bike shop and had a full service which they did number of things changed BB along with other stuff.
Just checked it out on a ride and it still feels harder than usual on hills, on the flats it seems fine. I'm a serious triathlete and looking at going sub 9hr in Ironman Austria next week but seriously do not have the confidence in my bike now at all.
Example one week I was going up a hill doing 80 rpm and the next going up same hill and doing 50 rpm and that was a massive effort. Today went up a 10% hill and my wattage was 350+watts and my speed was 6 mph this is crazy. God if I would do go that high watts when climbing hills in Austria I would blow up.
This write up is pretty rushed as I'm pushed for time, hope you can help me on what it could be, my thoughts are now going have to get another service when out in Austria spending another £100+ and possibly still doesn't get fixed.
Mike - Replica
Does your bike have gears? I'm not familiar with Triathlon bikes, sorry if question sounds silly. Hope you have found a fix
jtw82 - Replica
A short remark about how much force will then be needed to separate the old battery from the heated adhesive would be helpful. I found that even after I was able to begin the insertion of a plastic card between the battery and the case, it required a great deal of force to push the card further under the battery to complete the separation. Refer: free fnaf online
Martha Wilson - Replica
BMX cranksets are commonly sold independently to the base section (BB) and chainrings, instead of as a solitary unit 'chainset'. They comprise of the wrench arms, pivot (shaft) and any vital jolts and spacers. AssignmentGlobe
sallyjohn110 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 143
Tutti i Tempi: 35,510
