Salta al contenuto principale
Craig Electronics CMP773 Volume/Power Control Button Replacement
Cosa ti serve
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: passo 1, immagine 1 di 1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 2, immagine 1 di 1
    • Pry the back cover from the device along bottom edge.
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 3, immagine 1 di 1
    • Continue prying along each edge of the device until back cover is free.
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 4, immagine 1 di 1
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 5, immagine 1 di 2 Craig Electronics CMP773 Volume/Power Control Button Replacement: passo 5, immagine 2 di 2
    • Remove the old button and replace it with the new one.
Conclusione
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
IUPUI, Team S1-G5, Harley Spring 2018 Membro di IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 204
