Salta al contenuto principale
Craig Electronics CMP773 Screen Replacement
Cosa ti serve
  1. Craig Electronics CMP773 Screen Replacement, Screen: passo 1, immagine 1 di 2 Craig Electronics CMP773 Screen Replacement, Screen: passo 1, immagine 2 di 2
    • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
  2. Craig Electronics CMP773 Screen Replacement: passo 2, immagine 1 di 3 Craig Electronics CMP773 Screen Replacement: passo 2, immagine 2 di 3 Craig Electronics CMP773 Screen Replacement: passo 2, immagine 3 di 3
    • Insert a plastic opening tool between the screen and the back of the tablet.
    • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
    • Once roughly half of the case has been unlatched, it can be removed by hand.
  3. Craig Electronics CMP773 Screen Replacement: passo 3, immagine 1 di 2 Craig Electronics CMP773 Screen Replacement: passo 3, immagine 2 di 2
    • Use the spudger to gently pry the camera from the casing.
  4. Craig Electronics CMP773 Screen Replacement: passo 4, immagine 1 di 2 Craig Electronics CMP773 Screen Replacement: passo 4, immagine 2 di 2
    • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
    • Using needle nose pliers, remove the ribbon.
  5. Craig Electronics CMP773 Screen Replacement: passo 5, immagine 1 di 3 Craig Electronics CMP773 Screen Replacement: passo 5, immagine 2 di 3 Craig Electronics CMP773 Screen Replacement: passo 5, immagine 3 di 3
    • Remove the second screen power connection from the motherboard using the same procedure as step 4.
  6. Craig Electronics CMP773 Screen Replacement: passo 6, immagine 1 di 3 Craig Electronics CMP773 Screen Replacement: passo 6, immagine 2 di 3 Craig Electronics CMP773 Screen Replacement: passo 6, immagine 3 di 3
    • Remove four screws from the motherboard using the Phillips #00 screwdriver.
  7. Craig Electronics CMP773 Screen Replacement: passo 7, immagine 1 di 2 Craig Electronics CMP773 Screen Replacement: passo 7, immagine 2 di 2
    • Remove a single screw from the speaker using the Phillips #00 screwdriver.
    • Pry up on the locking tabs with the flat spudger.
  8. Craig Electronics CMP773 Screen Replacement: passo 8, immagine 1 di 1
    • Using needle nose pliers, remove the ground wire from the casing.
  9. Craig Electronics CMP773 Screen Replacement: passo 9, immagine 1 di 1
    • Using the plastic opening tool, remove the battery.
  10. Craig Electronics CMP773 Screen Replacement: passo 10, immagine 1 di 2 Craig Electronics CMP773 Screen Replacement: passo 10, immagine 2 di 2
    • With all screws and components removed, gently remove the motherboard from the casing.
  11. Craig Electronics CMP773 Screen Replacement: passo 11, immagine 1 di 3 Craig Electronics CMP773 Screen Replacement: passo 11, immagine 2 di 3 Craig Electronics CMP773 Screen Replacement: passo 11, immagine 3 di 3
    • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
  12. Craig Electronics CMP773 Screen Replacement: passo 12, immagine 1 di 3 Craig Electronics CMP773 Screen Replacement: passo 12, immagine 2 di 3 Craig Electronics CMP773 Screen Replacement: passo 12, immagine 3 di 3
    • Grasp the exposed screen corner and gently separate the screen from the housing.
Conclusione
Justin mersch
Membro da: 11/07/19
205 Reputazione
1 Guida realizzata
IUPUI, Team S3-G4, Harley Fall 2019 Membro di IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Membri
3 Guide realizzate
Un commento
What kind of battery does this device specifically use
Kris Miller - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 6
Tutti i Tempi: 200
