Salta al contenuto principale
Craig Electronics CMP773 Front and Rear Camera Replacement
Cosa ti serve
  1. Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: passo 1, immagine 1 di 2 Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: passo 1, immagine 2 di 2
    • Remove the two Phillips #00 screws from the bottom of the screen.
  2. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 2, immagine 1 di 2 Craig Electronics CMP773 Front and Rear Camera Replacement: passo 2, immagine 2 di 2
    • Insert a plastic opening tool underneath the screen.
    • Once the first tool is inserted, insert another opening tool along the same side of the tablet.
    • Pry them in opposite directions until the casing pops.
  3. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 3, immagine 1 di 2 Craig Electronics CMP773 Front and Rear Camera Replacement: passo 3, immagine 2 di 2
    • Move the opening tool along the edge of the tablet to continue popping the casing loose.
    • Once the casing is about half loose, remove it by hand.
  4. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 4, immagine 1 di 2 Craig Electronics CMP773 Front and Rear Camera Replacement: passo 4, immagine 2 di 2
    • Remove the tape from the power connection for the camera unit.
    • Unhinge the clamp on the camera power connection to expose the removable plug.
  5. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 5, immagine 1 di 1
    • Gently remove the power ribbon from the connector.
  6. Craig Electronics CMP773 Front and Rear Camera Replacement: passo 6, immagine 1 di 2 Craig Electronics CMP773 Front and Rear Camera Replacement: passo 6, immagine 2 di 2
    • Use the spudger to dislodge camera unit from the casing and remove it from the device.
Conclusione
Luke VanLangevelde
Membro da: 11/07/19
133 Reputazione
1 Guida realizzata
IUPUI, Team S3-G4, Harley Fall 2019 Membro di IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 85
