Salta al contenuto principale
Craig Electronics CMP773 Battery Replacement
Cosa ti serve
  1. Craig Electronics CMP773 Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Battery Replacement: passo 2, immagine 1 di 1
    • Pry the back cover from the device along the bottom edge.
  3. Craig Electronics CMP773 Battery Replacement: passo 3, immagine 1 di 1
    • Continue prying along the edge of the device until the back cover is free.
  4. Craig Electronics CMP773 Battery Replacement: passo 4, immagine 1 di 1
    • Pry the battery free from the device using a plastic opening tool.
  5. Craig Electronics CMP773 Battery Replacement: passo 5, immagine 1 di 1
    • Desolder the faulty battery wires.
  6. Craig Electronics CMP773 Battery Replacement: passo 6, immagine 1 di 1
    • Solder the replacement battery wires to the circuit board.
  7. Craig Electronics CMP773 Battery Replacement: passo 7, immagine 1 di 1
    • Apply adhesive between the replacement battery and the device before installation.
Conclusione
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced battery.
Jacob Hampton
Membro da: 03/26/18
145 Reputazione
1 Guida realizzata
IUPUI, Team S1-G5, Harley Spring 2018 Membro di IUPUI, Team S1-G5, Harley Spring 2018
IUPUI-HARLEY-S18S1G5
6 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 372
