Salta al contenuto principale
Craftsman Model 315.10721 Table Guard Replacement
Cosa ti serve
  1. Craftsman Model 315.10721 Table Guard Replacement, Table Guard: passo 1, immagine 1 di 1
    • Using a flathead screwdriver, remove the 1/2" flathead screw to allow the table guard to pivot.
  2. Craftsman Model 315.10721 Table Guard Replacement: passo 2, immagine 1 di 1
    • Pivot the table guard from its upright position to an angle.
    • Using a Phillips #1 screwdriver, remove the 1" Phillips screw and the nut on the opposite side.
  3. Craftsman Model 315.10721 Table Guard Replacement: passo 3, immagine 1 di 1
    • Using the Phillips #1 screwdriver, remove eight 1" Philips screws from the main case.
    • Carefully remove the main case to expose the inside of the saw.
  4. Craftsman Model 315.10721 Table Guard Replacement: passo 4, immagine 1 di 1
    • Remove the old table guard by gently lifting it away from the main case.
    • Replace the old table guard with the new one by placing it in the same orientation as the one removed.
Conclusione
Cal Poly, Team 4-47, Amido Fall 2014 Membro di Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Membri
5 Guide realizzate
2 Commenti
Where can I get a replacement table guard???
Roger Coyle - Replica
Where can I get a replacement table guard for this jig saw????????
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 599
