Salta al contenuto principale
Craftsman Model 315.10721 Cord Replacement
Cosa ti serve
  1. Craftsman Model 315.10721 Cord Replacement, Cord: passo 1, immagine 1 di 1
    • Remove the two 1" Phillips screws using a #1 Phillips screwdriver.
    • Remove the three 1/2" Phillips screws using a #1 Phillips screwdriver.
    • Once the five screws are removed, lift the handle cover from the saw.
    • Each screw has a corresponding nut on the opposite side of the power saw
  2. Craftsman Model 315.10721 Cord Replacement: passo 2, immagine 1 di 1
    • Remove the 1/2" Phillips screw that is securing the switch using a Phillips #1 screwdriver.
  3. Craftsman Model 315.10721 Cord Replacement: passo 3, immagine 1 di 2 Craftsman Model 315.10721 Cord Replacement: passo 3, immagine 2 di 2
    • Using a Phillips #00 screwdriver or a small diameter screwdriver, gently insert it into the leads. When the screwdriver is inserted into the lead, it will release the wire.
    • The leads are where the black and white wires from the power cord are plugged in.
    • Release both the black and white wires and gently pull them from the leads.
    • To install the new cord, insert the wires of the new cord in the same way that they were removed.
Conclusione
Cal Poly, Team 4-47, Amido Fall 2014 Membro di Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 483
