Salta al contenuto principale
Craftsman Model 315.10721 Blade Replacement
Cosa ti serve
  1. Craftsman Model 315.10721 Blade Replacement, Blade: passo 1, immagine 1 di 1
    • Be sure to unplug the saw before proceeding.
    • Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
    • Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
    • It is not necessary to completely remove the screws.
  2. Craftsman Model 315.10721 Blade Replacement: passo 2, immagine 1 di 1
    • Carefully take the replacement blade and insert it into the saw blade clamp.
    • To secure the blade, retighten both 7/32" flathead screws on the saw blade clamp.
Linea Traguardo
Cal Poly, Team 4-47, Amido Fall 2014 Membro di Cal Poly, Team 4-47, Amido Fall 2014
CPSU-AMIDO-F14S4G47
4 Membri
5 Guide realizzate
2 Commenti
Where can I get replacement blades for this saw.
Edward - Replica
Where can I get replacement blades for this saw?
Edward - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 74
Tutti i Tempi: 3,221
