Salta al contenuto principale
Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank Replacement
Cosa ti serve
  1. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: passo 1, immagine 1 di 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: passo 1, immagine 2 di 2
    • Remove the fuel line from the fuel tank with pliers.
    Chiedi a FixBot
    Aggiungi Commento
  2. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 2, immagine 1 di 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 2, immagine 2 di 2
    • Take off the fuel cap and place a safe container under the fuel line.
    • Make sure to drain all of the fuel from the fuel tank into the container.
    Chiedi a FixBot
    Aggiungi Commento
  3. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 3, immagine 1 di 2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 3, immagine 2 di 2
    • Remove the four support bolts on the top of the tank and motor with a crescent wrench or socket wrench.
    Chiedi a FixBot
    Aggiungi Commento
  4. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 4, immagine 1 di 1
    • Lift the fuel tank off of the lower supporting brackets.
    Chiedi a FixBot
    Aggiungi Commento
  5. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 5, immagine 1 di 1
    • Replace the cracked fuel tank and place the new one onto the lower supporting brackets.
    Chiedi a FixBot
    Aggiungi Commento
  6. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 6, immagine 1 di 1
    • Screw in the top four supporting bracket bolts with a crescent wrench or socket wrench to hold the new fuel tank in place.
    Chiedi a FixBot
    Aggiungi Commento
  7. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 7, immagine 1 di 1
    • Reconnect the fuel line and hose clamp.
    Chiedi a FixBot
    Aggiungi Commento
  8. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: passo 8, immagine 1 di 1
    • Fill the tank with fuel.
    • Check to make sure that the hose clamp is not leaking.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Megan Smith
Membro da: 10/07/19
169 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 28
Tutti i Tempi: 2,794
