Salta al contenuto principale
Cracked Grout Replacement
Cosa ti serve
  1. Cracked Grout Replacement, Cracked Grout: passo 1, immagine 1 di 2 Cracked Grout Replacement, Cracked Grout: passo 1, immagine 2 di 2
    • Identify the crack you will be repairing.
    • Surround it with Painters Tape.
  2. Cracked Grout Replacement: passo 2, immagine 1 di 1
    • Wear protective eye wear and a mask to shield yourself from dust and debris.
    • Use caution when handling the concrete grinder. If handled improperly it can lead to an injury.
    • Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
  3. Cracked Grout Replacement: passo 3, immagine 1 di 2 Cracked Grout Replacement: passo 3, immagine 2 di 2
    • Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
  4. Cracked Grout Replacement: passo 4, immagine 1 di 2 Cracked Grout Replacement: passo 4, immagine 2 di 2
    • Vacuum the dust and grout that was removed to reveal a clean and hollow space.
  5. Cracked Grout Replacement: passo 5, immagine 1 di 1
    • Color match your grout by using grout samples to get your desired color of grout.
  6. Cracked Grout Replacement: passo 6, immagine 1 di 3 Cracked Grout Replacement: passo 6, immagine 2 di 3 Cracked Grout Replacement: passo 6, immagine 3 di 3
    • Mix a scoop of grout and sealer to create a paste.
  7. Cracked Grout Replacement: passo 7, immagine 1 di 3 Cracked Grout Replacement: passo 7, immagine 2 di 3 Cracked Grout Replacement: passo 7, immagine 3 di 3
    • Take the rubber grout float and press the grout paste securely into the crack.
  8. Cracked Grout Replacement: passo 8, immagine 1 di 2 Cracked Grout Replacement: passo 8, immagine 2 di 2
    • Take the grouting sponge and smooth out the grout evenly.
    • Let the grout sit and harden for twenty-four hours.
  9. Cracked Grout Replacement: passo 9, immagine 1 di 1
    • Your new grout is dry and ready for use.
Conclusione
To repair any other cracks in grout, repeat these steps.
Altre 7 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 208
Tutti i Tempi: 3,729
