Salta al contenuto principale
Cr-48 Chromebook SSD Replacement
Cosa ti serve
  1. Cr-48 Chromebook SSD Replacement, Battery: passo 1, immagine 1 di 3 Cr-48 Chromebook SSD Replacement, Battery: passo 1, immagine 2 di 3 Cr-48 Chromebook SSD Replacement, Battery: passo 1, immagine 3 di 3
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: passo 2, immagine 1 di 2 Cr-48 Chromebook SSD Replacement, Remove Rear Rubber Feet: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Cr-48 Chromebook SSD Replacement, Remove Screws: passo 3, immagine 1 di 3 Cr-48 Chromebook SSD Replacement, Remove Screws: passo 3, immagine 2 di 3 Cr-48 Chromebook SSD Replacement, Remove Screws: passo 3, immagine 3 di 3
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Cr-48 Chromebook SSD Replacement: passo 4, immagine 1 di 3 Cr-48 Chromebook SSD Replacement: passo 4, immagine 2 di 3 Cr-48 Chromebook SSD Replacement: passo 4, immagine 3 di 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: passo 5, immagine 1 di 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: passo 5, immagine 2 di 3 Cr-48 Chromebook SSD Replacement, Locate SSD and Remove Screw: passo 5, immagine 3 di 3
    • Find the SSD located on a corner of the side directly opposite where the laptop screen and device body are connected.
    • Remove one black screw on the SSD using a PH #00 screwdriver.
    • Size ph#00, approximately 3 mm long.
    • Once unscrewed, the SSD will pop up from the device.
  6. Cr-48 Chromebook SSD Replacement, Remove SSD: passo 6, immagine 1 di 2 Cr-48 Chromebook SSD Replacement, Remove SSD: passo 6, immagine 2 di 2
    • Firmly grasp the SSD with two fingers slightly upwards and pull.
Conclusione
Altre 5 persone hanno completato questa guida.
Athar
Membro da: 09/09/14
365 Reputazione
2 Guide realizzate
CSU Fullerton, Team 2-2, Bruce Fall 2014 Membro di CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 53
Tutti i Tempi: 3,253
