Introduzione
The Cr-48 Chromebook shipped with a combined Wi-Fi / Cellular network card that can be easily removed and replaced if necessary. Use this guide to replace a malfunctioning network card in a Cr-48 Chromebook.
Cosa ti serve
Slide the switch on the bottom of the laptop until the battery pops out.
Once the battery pops out, you can remove it.
Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
Remove Screw securing network card.
Size ph#00, approximately 3 mm long.
Pull the network card to remove it from the device.
Un commento
The card identified in the pictures is not a combined Wi-Fi / Cellular card. It is just a 3G cellular card; the WiFi card is the other card tucked under the flat ribbon next to the card pictured in this guide
