Salta al contenuto principale
Cowin E7 Ear Cushion Replacement
Cosa ti serve
  1. Cowin E7 Ear Cushion Replacement, Ear Cushion: passo 1, immagine 1 di 1
    • Inspect the seal around the edge of each ear cushion for damage or instability.
    • Make note of which ear cushion needs to be replaced.
  2. Cowin E7 Ear Cushion Replacement: passo 2, immagine 1 di 1
    • Firmly grasp the ear cushion on one side and pull up.
    • The ear cushion is only attached by a few spots of glue, so it should not take much force to remove.
  3. Cowin E7 Ear Cushion Replacement: passo 3, immagine 1 di 1
    • Spread multipurpose glue around the edge of the seal.
    • Keep in mind that the more glue you use, the harder it will be to remove the ear cushions again.
    • Place the replacement ear cushions where the damaged cushions were.
    • Hold for at least thirty seconds to ensure the glue has time to dry and seal the new cushions to the headphones.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Jacob Burrer
Membro da: 03/26/22
439 Reputazione
2 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 189
Tutti i Tempi: 4,939
