Salta al contenuto principale
Corsair Katar Optical Sensor Replacement
Cosa ti serve
  1. Corsair Katar Optical Sensor Replacement, Corsair Katar Disassembly: passo 1, immagine 1 di 2 Corsair Katar Optical Sensor Replacement, Corsair Katar Disassembly: passo 1, immagine 2 di 2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar Optical Sensor Replacement: passo 2, immagine 1 di 1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar Optical Sensor Replacement: passo 3, immagine 1 di 2 Corsair Katar Optical Sensor Replacement: passo 3, immagine 2 di 2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar Optical Sensor Replacement: passo 4, immagine 1 di 1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar Optical Sensor Replacement, Scroll Wheel: passo 5, immagine 1 di 2 Corsair Katar Optical Sensor Replacement, Scroll Wheel: passo 5, immagine 2 di 2
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
  6. Corsair Katar Optical Sensor Replacement: passo 6, immagine 1 di 1
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
  7. Corsair Katar Optical Sensor Replacement: passo 7, immagine 1 di 1
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
  8. Corsair Katar Optical Sensor Replacement, Optical Sensor: passo 8, immagine 1 di 2 Corsair Katar Optical Sensor Replacement, Optical Sensor: passo 8, immagine 2 di 2
    • Flip the motherboard over and remove the clear plastic cover from the bottom of the board.
  9. Corsair Katar Optical Sensor Replacement: passo 9, immagine 1 di 2 Corsair Katar Optical Sensor Replacement: passo 9, immagine 2 di 2
    • Desolder the 20 connecting pins to remove the optical sensor.
Conclusione
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 974
