Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
If the DPI (dots per inch) sensor inside your Corsair Katar mouse is not operating correctly, this guide will show you how to replace it.
Parti
Nessuna parte specificata.
  1. Unplug your mouse before starting. Flip the mouse over so the bottom is facing up.
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse. Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  5. Detach the bottom of the mouse from the upper shell.
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  6. Use the JIS 0 screwdriver to remove the two 5mm screws holding the DPI sensor. Use the JIS 0 screwdriver to remove the two 5mm screws holding the DPI sensor.
    • Use the JIS 0 screwdriver to remove the two 5mm screws holding the DPI sensor.
  7. Lift the DPI sensor away from the mouse shell.
    • Lift the DPI sensor away from the mouse shell.
Conclusione
Altre 2 persone hanno completato questa guida.
UW Tacoma, Team S1-G3, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G3, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G3
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 161
