Introduzione
If your Corsair Harpoon RGB Wireless Mouse (RGP0075) is suspected to be a dead battery, then use this guide to gain the knowledge to replace it.
The battery in the mouse gives it wireless functionality. To make sure, plug your mouse into a micro USB cable, let it charge for a while and see if the Bluetooth or 2.4Ghz single is working. If it still does not work, then continue with this guide.
This mouse uses a battery to hold its power so that it can be useable without a cable, and in rare cases, these batteries can give up and become unusable. This takes away from the wireless ability of the mouse.
Steps 3 and 5 of this guide require you to unplug the circuit board and battery along with taking out the battery. Avoid touching the circuit board to avoid damaging it.
Cosa ti serve
Flip the mouse upside down.
Use a spudger to help pry the 4 mouse feet from the bottom of the mouse.
Start at the small grooves at the edge of each mouse foot.
Use a spudger to pry along the seam between top and bottom of the mouse.
Gently separate the top and bottom case until you can see the internals of the mouse.
Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket and remove the cable attaching the top and bottom of the mouse.
Use the point of a spudger or opening pick to push on alternating sides of the battery connector to "walk" it out of its socket and remove the battery cable.
Use a spudger and wedge it between the battery and the mouse.
Work the spudger left and right to slowly lift the adhesive.
Once it is loose, lift and remove the battery.
Altre 2 persone hanno completato questa guida.
