Salta al contenuto principale
Coolpix S01 The power button won't turn on Replacement
Cosa ti serve
  1. Coolpix S01 The power button won't turn on Replacement, The power button won't turn on: passo 1, immagine 1 di 3 Coolpix S01 The power button won't turn on Replacement, The power button won't turn on: passo 1, immagine 2 di 3 Coolpix S01 The power button won't turn on Replacement, The power button won't turn on: passo 1, immagine 3 di 3
    • First make sure the camera is powered off.
    • Then take the Hex and PH000 bit to remove a 2mm screw on the left side of the camera.
    • Next, remove the 2mm screw on the right side of the camera.
  2. Coolpix S01 The power button won't turn on Replacement: passo 2, immagine 1 di 3 Coolpix S01 The power button won't turn on Replacement: passo 2, immagine 2 di 3 Coolpix S01 The power button won't turn on Replacement: passo 2, immagine 3 di 3
    • Remove the 3mm screw from the bottom of the camera.
    • Once the 2mm and 3mm screws are removed, use the plastic opening tool to lift the sides of the camera and reveal the inside of the camera.
    • Be sure to remove the battery before continuing to repair.
  3. Coolpix S01 The power button won't turn on Replacement: passo 3, immagine 1 di 3 Coolpix S01 The power button won't turn on Replacement: passo 3, immagine 2 di 3 Coolpix S01 The power button won't turn on Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. Using the hex and the J000 bit remove the two 1mm screws.
    • Take the needle nose tweezers to remove the power button.
  4. Coolpix S01 The power button won't turn on Replacement: passo 4, immagine 1 di 1
    • You have successfully removed the power button and can replace it if needed.
Conclusione
Rieana Hayes
Membro da: 10/13/15
101 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 835
