Salta al contenuto principale
Coolpix S01 Screen Cover Replacement
Cosa ti serve
  1. Coolpix S01 Screen Cover Replacement, Screen Cover: passo 1, immagine 1 di 3 Coolpix S01 Screen Cover Replacement, Screen Cover: passo 1, immagine 2 di 3 Coolpix S01 Screen Cover Replacement, Screen Cover: passo 1, immagine 3 di 3
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
  2. Coolpix S01 Screen Cover Replacement: passo 2, immagine 1 di 3 Coolpix S01 Screen Cover Replacement: passo 2, immagine 2 di 3 Coolpix S01 Screen Cover Replacement: passo 2, immagine 3 di 3
    • Next, remove the 2 mm screw from the right side of the camera
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Screen Cover Replacement: passo 3, immagine 1 di 3 Coolpix S01 Screen Cover Replacement: passo 3, immagine 2 di 3 Coolpix S01 Screen Cover Replacement: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • With the screen facing outward, locate the orange ribbon cable from the motherboard.
    • With the straight tweezers, gently pull out the orange ribbon cable from the motherboard.
  4. Coolpix S01 Screen Cover Replacement: passo 4, immagine 1 di 3 Coolpix S01 Screen Cover Replacement: passo 4, immagine 2 di 3 Coolpix S01 Screen Cover Replacement: passo 4, immagine 3 di 3
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen.
    • Use the plastic tool to gently lift the screen out from the upper left corner until the seal is broken.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 542
