Salta al contenuto principale
Coolpad Defiant Daughterboard Replacement
Cosa ti serve
  1. Coolpad Defiant Daughterboard Replacement, Back Cover: passo 1, immagine 1 di 2 Coolpad Defiant Daughterboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Daughterboard Replacement: passo 2, immagine 1 di 1
    • Remove the back cover from your device.
  3. Coolpad Defiant Daughterboard Replacement, Battery: passo 3, immagine 1 di 1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Daughterboard Replacement, Daughterboard: passo 4, immagine 1 di 2 Coolpad Defiant Daughterboard Replacement, Daughterboard: passo 4, immagine 2 di 2
    • Remove all fifteen screws using the Phillips #000 screwdriver.
    • Remove the back panel after all screws are removed.
  5. Coolpad Defiant Daughterboard Replacement: passo 5, immagine 1 di 3 Coolpad Defiant Daughterboard Replacement: passo 5, immagine 2 di 3 Coolpad Defiant Daughterboard Replacement: passo 5, immagine 3 di 3
    • Disconnect the metal cable using the plastic spudger.
    • The remove the glued down speaker from the backing.
    • Disconnect the little black wire from lower logic board.
  6. Coolpad Defiant Daughterboard Replacement: passo 6, immagine 1 di 1
    • Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
Conclusione
Elijah Gastin
Membro da: 09/21/18
100 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 474
